Same Prefix for SIP and E-1 trunk
Re: Same Prefix for SIP and E-1 trunk
ahqswitchroom4466 wrote: 08 Jul 2023 14:01
haroun wrote: 13 Jun 2023 08:28 So you need ARS
How to configure ARS in SIP trunk and E-1 for same prefix
Problem - solved or not?
ARS - configured as usual:
- ARS prefix with logical discriminator
- in real discriminator - dialed number declared with ARS route list number
- in ARS route list - two routes - with SIP and E1 TG
- in time based route list - prefered order for using - at first to use SIP or E1.
ahqswitchroom4466
Post by ahqswitchroom4466 »
vad wrote: 12 Jul 2023 23:25
Sir can me give a documents
Md Afzal Hossain
System Admin
i have already sent you a pm with the config did you received it
ahqswitchroom4466
haroun wrote: 13 Jul 2023 04:37 i have already sent you a pm with the config did you received it
Sir after config when i dial prefix code telephone show Feature rejected.
Md Afzal Hossain
System Admin
ok
when you dial the prefix and you got features rejected , you dial it from mitel or oxe ?!
if from oxe you have to check PNC of the user he should be authorized to access that dialed area and the tkgp , also did you create the time based route route ?
if you dialed it from mitel and you get that message check the PNC of rhe tgp between mitel and oxe and its entity the real discriminator and logic one shoudl managed
Return to “Translator”
