looks like some thing wrong in xb011001 netadmin
ole and CPU positions:
Role of the CPU : MAIN
CPU position : 06 !!!!20
>>>>>>>CPU address : Not Declared????
compare the ps -edf in both cpu can help , or past the incidents when the cpu b is restarded
can you perform a double bascul?
Problem with CS - call servers, both CS are in main status!?
- frank
Re: Problem with CS - call servers, both CS are in main status!?
looks like something changed in your network.
I would redo the net admin configuration from scratch.
what happens if you have CPUA MAIN up and running, and from CPUB (phone application not running) you run the mastercopy command?
It is not possible to use the bascul command when the servers are not visible.
(1101)xa011001> twin
Fri Oct 18 13:17:21 CEST 2024
Usage : twin [Redundancy Cpu Enable (y/n)]
Role and CPU positions:
CPU position : 06
CPU address : 172.22.26.2
Twin CPU position : UNKNOWN
Twin CPU address : UNKNOWN
Redundancy State:
Duplicated configuration : YES
Wished sig. transfer mode : C1 signalling channel
Transmission CPU-CPU : KO
Telephony redundancy : KO
monitel redundancy : KO
memloader redundancy : KO
All applications redundancy : KO
(1101)xa011001> role -b
MAIN stand-by CPU state : NOT READY
(1101)xa011001> bascul
Fri Oct 18 13:17:30 CEST 2024
The Stand-By CPU is absent or not initialized. Command Unavailable.
(1101)xb011001> bascul
Fri Oct 18 13:11:13 CEST 2024
CPU position : 06
Redundancy State:
cpu position couldn't be same in redundancy case
one in position 6 the otherone in position 20 (a and b)
cpu b :
CPU position : 06------should be 20
CPU address : Not Declared the netadmin is not token in consideration
cpu b :
