Hi.
Thanks for your advise.
Yes, i tried to turn off and turn on this parameter, but unfortunately it doesn't works for me. STATUS message is still sent in the call log. It seems to me that the station doesn't respond to these parameter. Yesterday , my ISP told me again that the problem on my side (i have to stop sending "message STATUS"). But why , if i can make a call from operator B and it's works. Bellow call log with parameter " Specific EI status for GSM = off"
Traces Analyser activated
| (571302:000002:03609) Concatenated-Physical-Event :
| long: 57 desti: 0 source: 0 cryst: 0 cpl: 9 us: 0 term: 1 type a5
| tei: 0 >>>> message received : SETUP [05] Call ref : 02 46
| SENDING COMPLETE
| IE:[18] CHANNEL (l=3) a1 83 81 -> T2 : B channel 1 preferred
| IE:[1e] PROGRESS_ID (l=2) 00 81
| IE:[6c] CALLING_NUMBER (l=12) -> 01 83 Num : XXXXXXXXXX
| IE:[70] CALLED_NUMBER (l=8) -> c1 Num : XXXXXXX
| (571302:000003:03489) 3489: Send_IO1 (link-nbr=9, sapi=0, tei=0) :
| long: 26 desti: 0 source: 15 cryst: 0 cpl: 9 us: 8 term: 1 type a5
| tei: 0 <<<< message sent : STATUS [7d] Call ref : 82 46
| IE:[08] CAUSE (l=3) 81 e4 1e -> [e4] INVALID INFORMATION ELEMENT CONTENTS
| IE:[14] CALL_STATE (l=1) 06
| (571302:000004:03489) 3489: Send_IO1 (link-nbr=9, sapi=0, tei=0) :
| long: 23 desti: 0 source: 15 cryst: 0 cpl: 9 us: 8 term: 1 type a5
| tei: 0 <<<< message sent : CALL PROC (02) Call ref : 82 46
| IE:[18] CHANNEL (l=3) a9 83 81 -> T2 : B channel 1 exclusive
| (571302:000005:03489) 3489: Send_IO1 (link-nbr=9, sapi=0, tei=0) :
| long: 22 desti: 0 source: 15 cryst: 0 cpl: 9 us: 8 term: 1 type a5
| tei: 0 <<<< message sent : ALERT (01) Call ref : 82 46
| IE:[1e] PROGRESS_ID (l=2) 81 88
| (571303:000006:03609) Concatenated-Physical-Event :
| long: 22 desti: 0 source: 0 cryst: 0 cpl: 9 us: 0 term: 1 type a5
| tei: 0 >>>> message received : RELEASE [4d] Call ref : 02 46
| IE:[08] CAUSE (l=2) 84 9f -> [9f] NORMAL, UNSPECIFIED
| (571303:000007:03609) Concatenated-Physical-Event :
| long: 25 desti: 0 source: 0 cryst: 0 cpl: 9 us: 0 term: 1 type a5
| tei: 0 >>>> message received : STATUS [7d] Call ref : 02 46
| IE:[08] CAUSE (l=2) 84 e2 -> [e2]
| MESSAGE NOT COMPATIBLE WITH CALL STATE OR MESSAGE TYPE NON-EXISTENT
| IE:[14] CALL_STATE (l=1) 13
| (571303:000008:03489) 3489: Send_IO1 (link-nbr=9, sapi=0, tei=0) :
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 82 46
| IE:[08] CAUSE (l=2) 81 90 -> [90] NORMAL CALL CLEARING
| (571303:000009:03609) Concatenated-Physical-Event :
| (571303:000010:03489) 3489: Send_IO1 (link-nbr=9, sapi=0, tei=0) :
| IE:[08] CAUSE (l=3) 81 e5 00 -> [e5] MESSAGE NOT COMPATIBLE WITH CALL STATE
