Echo
Re: Echo
robguez wrote:I hope I can help that I have same problem on the Echo's IP phones when there are outgoing calls on analog lines (PSTN or GSM Analog Gateway). phones digital and analog works well and is not heard the echo.
Modify the type of line in trunk category (make tests with short line, medium etc.)
Regards.
whipps23
Re: Echo
Post by whipps23 »
When I look at the IP Ticket viewer, there is BFI on the call. What causes BFI. Moreover, what settings on the Alcatel equipment can lead to BFI. Is there any tools to see a graph of the call like on wireshark?
kliffie
Re: Echo
Post by kliffie »
We had the same issue, the solution for us was new handset on the 80 IP-sets delivered from Alcatel.
There was some manufacture-problems with the handsets of the 4038IP.
Return to “GENERAL”
