Statistic Manager Password problem after upgrade from rel2.1
et
Re: Statistic Manager Password problem after upgrade from rel2.1
Post by et »
Do you use some kind of automatic language switching software on your PC? I know one on Russian - puntoswitcher. Some time it make trouble to enter passwords.
fernan05
Post by fernan05 »
No, I don t use any soft.
On the other hand:
I have tested Statistics Manager in 2 others OXO with Release 700_023_003. In the first, I can enter through the pass k*******; but in the second, I can not with any key.
I don t know how it works
Any idea
Thanks for your help
Return to “Applications”
