Used that on one system, but the problem came back once.fdurante wrote:Thank you for your answers !
In TC0918 documentation, a workaround is added : Use the save_ifcfgeth0 command !
So, I think it will save the IP configuration of the GD board but when I will reproduce the loop problem with GD IP configuration lost, what will OXE do ?
At the end of this documentation, this issue will be fixed in a next patch !
I download the last Alcatel patch f540136b ! Do you know if this patch will resolve the GD loop problem ?
It is said to be fixed in R9.
Regards.
