Configure OminPCX office
Benjamin78au
Re: Configure OminPCX office
go in to your computers, files and folders, and look at where OMC or pm5 is installed,
You should find an expert.dll, rename that, and restart the management software,
go in as admin, and you will beable to configer some of the settings, this maybe enought to get you out of trouble.
soenke
You can rename the expert.dll in expert.dl. So you have acces with admin account and you can make a backup.rodolfo.rodriguezv wrote:ok,
are there option to reset the password without loss the configration?
anything to know the password?
are there a kind of master password or something like that?
People did install the device isn't here.
Then you make a cold reset and the installer password is default.
soenke
forget my last post, i did not read the 2 page...soenke wrote:You can rename the expert.dll in expert.dl. So you have acces with admin account and you can make a backup.rodolfo.rodriguezv wrote:ok,
rodolfo.rodriguezv
thank for response, i tried that, but the result is same "FTP-Connection establishment failed The password was not allowed"Benjamin78au wrote:go in to your computers, files and folders, and look at where OMC or pm5 is installed,
from 4035 terminal the password is valid, but from PM5 no.
where can i get PM5 update (could be the trouble is version)
keypulse
Do you still have the install package for PM5? If so:rodolfo.rodriguezv wrote:thank for response, i tried that, but the result is same "FTP-Connection establishment failed The password was not allowed"Benjamin78au wrote:go in to your computers, files and folders, and look at where OMC or pm5 is installed,
- Uninstall PM5
- Unzip the PM5 install software to a folder
- Delete/rename the file expert.dll from that folder
- Run setup.exe
You should now be able to log in as admin (easyplus) using the default admin pass, the Installer and Manufacturer options will have gone.
Then Comm> Read all from PBX... File> Save as. Then Comm> Disconnect> File> Backup> Store (save .cdb file to desktop).
Then uninstall PM5 again and reinstall with expert.dll intact. Login to the PBX from your 4035 in Operator mode and cold reset. Then PM5, File> Backup> Restore (the .cdb file from your desktop). File> Open (your file). Comm> Connect using (now default!) installer pass. Write the database back to PBX.
rodolfo.rodriguezv
Thanks for response,keypulse wrote:Do you still have the install package for PM5? If so:rodolfo.rodriguezv wrote:thank for response, i tried that, but the result is same "FTP-Connection establishment failed The password was not allowed"Benjamin78au wrote:go in to your computers, files and folders, and look at where OMC or pm5 is installed,
- Uninstall PM5
- Run setup.exe
I tried to install replacing expert.dll, all is ok, but when run chose tipically installation, send admin's password, but the result is the same error, "FTP-Connection establishment failed. The password was not allowed"
keypulse
Strange. And you're able to log in as admin from a 4035?rodolfo.rodriguezv wrote:Thanks for response,
When you remove the expert.dll, you start PM5 and get the welcome screen. The bottom option "Expert" should be greyed out and you can only log-in by selecting "Modification Typical". If "Expert" isn't greyed out on the welcome screen, you've gone wrong somewhere...
rodolfo.rodriguezv
Hi, thanks for all
i got OMC, a can connect.
best regards
Rodolfo Rodríguez Valdé�
best regards
dendy
Need Help For Login From omc
iwas trying to login using default password on expert omc 51.0.9
but this error appear
HTTPS[login.4] - soap login error - error code [29]
any suggestion pls
any suggestion pls
