hi, is there any one can help me with this post, can some one assist pls...
thanks
Reset board everyday at 5 am
Re: Reset board everyday at 5 am
what do you need?morio wrote: 16 Aug 2022 05:49 hi, is there any one can help me with this post, can some one assist pls...
thanks
hi OldBoy,
i need to restart GD3 boards on a weekly or daily basis to resolve a strange issue with analog extensions. im not aware of any script writing or anything. so if there is a way to schedule a re boot by script in oxe, can you guide me to it..
regs
Morio
regs
Morio
Just add one of the following lines on the crontab using the command "crontab -e"
If every day at 2am
00 02 * * * /usr2/oneshot/mtcl/tool rstcpl Cr Cpl
If every monday at 2am
00 02 * * 0 /usr2/oneshot/mtcl/tool rstcpl Cr Cpl
Note that you must replace Cr and Cpl with the position of the GD that you want to restart
If every day at 2am
Correction:
the line
is for every sunday
for every monday is:
00 02 * * 1 /usr2/oneshot/mtcl/tool rstcpl Cr Cpl
the line
is for every sunday
hi sadim
im getting the below stuff on telnet when i enter "crontab -e",,, what should i do,,
# To modify this file please use crontab -e, cfgCron is now obsolete.#
# Please don't modify the PATH, if you want to add / modify #
# an instruction in this case you must indicate the complete path. #
# example : #
# Good : 0 * * * * /tmpd/essay/my_program > /tmpd/result.txt #
# Bad : 0 * * * * my_program > /tmpd/result.txt #
PATH = /usr/bin/rsh2ssh:/sbin:/usr/sbin:/bin:/usr/bin:/usr/X11R6/bin
0,10,20,30,40,50 * * * * /DHS3bin/oneshot/mtcl/calllogupd > /tmpd/calllogupd.out 2>/tmpd/calllogupd.errs
0 * * * * /DHS3bin/servers/hotbascul >/tmpd/hotbascul.out 2>/tmpd/hotbascul.errs
30 1 * * * /DHS3bin/servers/fnclrpt -r >/tmpd/fnclrpt.out 2>/tmpd/fnclrpt.errs
0,10,20,30,40,50 * * * * /usr/sbin/logrotate -s /DHS3dyn/incid/logrotate.status /DHS3data/incid/logrotate.conf
"/tmp/crontab.XXXXikkbFk" 13 lines, 1013 characters
# example : #
You need enter the data as sadim has stated but be carful when you do it, basically you are running the vi command.
can i suggest you do a search on the vi command for linux to make sure you insert correctly and then also save and write the file correctly
As oldboy says, it is like vi.
But if you are not comfortable using the crontab command, you can perform the following sequence of commands
crontab -l > mycrontab
Note: on the next line do not forget to change Cr and Cpl by the GD position (ex: 2 0)
echo "00 02 * * 0 /usr2/oneshot/mtcl/tool rstcpl Cr Cpl" >> mycrontab
crontab mycrontab
Then, and in order to check if the crontab contents its ok:
crontab -l
crontab mycrontab
crontab -l
hi,, thanks for the detailed info. i will try it and check.. thank you ''sadim and oldboy''
good news,
my trial worked. i set up to rest a cupler at 3 am and it works fine.
great thanks to all of you,
now one more thing. if i want to remove the line
00 02 * * * /usr2/oneshot/mtcl/tool rstcpl 0 3
or disable the auto reboot what should i do..
thanks again
morio
thanks again
morio
