Manual provisioning of the 4068? SIP capability?
Re: Manual provisioning of the 4068? SIP capability?
You configure in OXE a domain with ipp's and give settings for relm/dns/proxy etc on the user you configure sip user number and passord. when the phone looses connection to the CS it looks for the sip server/proxy and connects to that. When the ipp sees the CS it switches back to the OXE. it is meant to be used in a remote site that has a sip gateway as a backup path to the outside world when the link to the OXE is down. As far as I know at present there is no way to configure the 4008/18 as stand alone sip unless you set them up and remove the OXE.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
ftoure
I'm struggling trying to configure a 4068G phone. I'm using TFTP protocol and the phone tries to download some binary files. A file name bin4068G seems to be mandatory. Does anyone have it in some place?
Famory
Here is the the trace I'm getting, then the phone re-starts.
Famory
Connection received from 172.27.231.100 on port 1024 [24/03 19:28:23.573]
Read request for file <noesip4068G>. Mode octet [24/03 19:28:23.588]
OACK: <timeout=5,blksize=1428,tsize=1748014,> [24/03 19:28:23.588]
Using local port 3796 [24/03 19:28:23.588]
<noesip4068G>: sent 1225 blks, 1748014 bytes in 25 s. 12 blks resent [24/03 19:28:48.963]
Connection received from 172.27.231.100 on port 1024 [24/03 19:28:50.963]
Read request for file <bin4068G-header>. Mode octet [24/03 19:28:50.979]
File <bin4068G-header> : error 2 in system call CreateFile Le fichier spécifié est introuvable. [24/03 19:28:50.979]
Connection received from 172.27.231.100 on port 1024 [24/03 19:28:50.979]
Read request for file <bin4068G>. Mode octet [24/03 19:28:50.979]
File <bin4068G> : error 2 in system call CreateFile Le fichier spécifié est introuvable. [24/03 19:28:50.979]
Connection received from 172.27.231.100 on port 1024 [24/03 19:29:07.041]
Read request for file <noesip4068G-header>. Mode octet [24/03 19:29:07.041]
File <noesip4068G-header> : error 2 in system call CreateFile Le fichier spécifié est introuvable. [24/03 19:29:07.041]
Connection received from 172.27.231.100 on port 1024 [24/03 19:29:07.057]
Read request for file <noesip4068G>. Mode octet [24/03 19:29:07.057]
OACK: <timeout=5,blksize=1428,tsize=1748014,> [24/03 19:29:07.057]
Using local port 3833 [24/03 19:29:07.057]
<noesip4068G>: sent 1225 blks, 1748014 bytes in 25 s. 12 blks resent [24/03 19:29:32.385]
Connection received from 172.27.231.100 on port 1024 [24/03 19:29:34.385]
Read request for file <bin4068G-header>. Mode octet [24/03 19:29:34.385]
File <bin4068G-header> : error 2 in system call CreateFile Le fichier spécifié est introuvable. [24/03 19:29:34.385]
Read request for file <bin4068G>. Mode octet [24/03 19:29:34.385]
File <bin4068G> : error 2 in system call CreateFile Le fichier spécifié est introuvable. [24/03 19:29:34.385]
aymen
I have an ip touch 4068EE and I'm facing a problem with its binary files , it always keeps looking for noesip4068G , bin4068-header ,noesip4068G-header,bin4068G
any kind of help is appreciated
you need an alcatel-lucent callserver to get this phone working.
regards...
regards...
