Thank you all for the reply ...
I figured out, that the configuration on boath OXE and OXO should be OK (in the lab it works perfect), so it is the matter of the network.
Does anybody know which ports are important on OXE and OXO for H323 signalization and for RTP? I could not find this information on businesspartner webpage, but I need that so tha I can talk to network administrator.
Thanks,
Best regards,
Miha
H323 call without ringback tone
Re: H323 call without ringback tone
Here is some info about.
I hope you will find in the document all information about port mapping on Oxe.
Bye
Bye
OmniPCX Enterprise ACSE
OmniTouch ICS ACSE
OmniPCX Enterprise ACPS
OmniPCX Office ACSE
Alcatel-Lucent VAD
OmniTouch ICS ACSE
OmniPCX Office ACSE
Alcatel-Lucent VAD
HI,
generally, when i have this kind of problem i put the Board signalling (GD or INt-IP) into France:
x Shelf Address : 0 x
x Board Address : 1 x
x x
x Interface Type + INTIPA x
x Virtual board + NO x
x Serial number : -------------- x
x Usage State + Active x
x Operational State + Enabled x
x Main/Standby State + Main (Master) x
x Country Protocol Type + France <--------
x Incidents Teleservice + YES x
x IP Compression Daughter Board + 1 GIP4-4 x
x Nb of Compressors for Gateway : 4 x
x Nb of Compressors for IP Devices : 5 x
x After change parameter, reboot the board
x x
