OmniPCX Complete System Reset / Cold Reset
Re: OmniPCX Complete System Reset / Cold Reset
For cold reset - not sure.
For LoLa - you need OXO SW and licenses.
hnorbi
Post by hnorbi »
The cold reset clear the config only, the sw and lic is not cleared.
if you use lola, you may need the software and you may need known the lic key.
if you have a saved databade, you can get the keys from it.
Im newbie, but I hope an expert confim it.
hnorbi
Post by hnorbi »
Ohh, vad was the faster, but it seems said same
CR87
Post by CR87 »
Oh, interesting!
Thank you very much for you support.
rkraehen
Post by rkraehen »
With a cold reset you can erase customer data only and with LoLa you'll need also the system sw and licenses
jitendrapra
Post by jitendrapra »
tot3nkopf wrote: 30 Sep 2009 02:51 You can use LoLa and reload the software.
What does LoLa mean? And how does it work?
mstepan
Post by mstepan »
Hello together,
I have the exact same issue with a OmniPCX Large.
A friend of mine gave it to me as a gift and I was interested in playing around with it.
Unfortunately, I have no passwords for it and I am unable to Log In. :( The Ip Address is known to me.
Any suggestions?
Kind Regards
Marko
Return to “Beginner's questions about the OmniPCX OFFICE”
