automatic hook-off
Re: automatic hook-off
you can in oxe, it s called master conference.
L_lefante
Post by L_lefante »
Many thanks frank. You are right, it appears under "Announcement" feature in Mastered Conference doc.
I will try it.
yes, as answered in another of your posts. that's called master conference.
Return to “ON SITE TROUBLES”
