DECT user changing between IBS and RBS
Everything about the PWT, IBS, RBS, DECT..
Re: DECT user changing between IBS and RBS
And during registration - DECT set registered with PLI=31?
Normaly if declared PLI f.e. 27 - DECT sets without "network" rights registered with PLI=31 (you can use exstended format for "dectinston" command).
Eliott
Post by Eliott »
No. PLI for Mixed DECT systems will be calculated automatically to fit both PARI values.
It's not good to have the same PARI and it's not allowed to have overlapping of radio coverage.
Minimum distance is -90 dB plus 90 meter.
Return to “Wireless configuration and sets”
