4XX8EE Phones with Asterisk
MM-P
Post by MM-P »
Yes it only was the parameter:
"supported_language=0"
Alcatel documented it wrong with "language=0".
But now it works!!! Thank you very much!!!
R2D2
Post by R2D2 »
Hi all,
I'm having the same pb.
Trying to use IPTouch 4018 in SIP mode, i get 'Invalid parameters !' and reset.
The phone download sipconfig.txt and sipconfig-adrrMAC.txt but on the syslog server i get:
Nov 10 16:58:55 alcaphone-1 00:00:00 000-00:00:15.310 INIT : Checking Mandantory Parameter: telnet_passwd Invalid !
But telnet_password is set, i also tried telnet_passwd but no way ...
I'm using sip version 1.10.91.
Anyone can help ?
Second Post: (Edited by Benny)
i also had
user.info:Nov 10 17:07:19 alcaphone-dyn-1 00:00:00 000-00:00:35.170 INIT : sipconfig_init: missing mandatory CS polling timer
in the log.
I don't see which parameter i forgot ... i put
binary_polling_timer=10
config_polling_timer=10
but no way ...
Third post: (Edited by Benny)
Hi again,
do you have anything else than
APPLICATION_TYPE=APPL_SIP
in your lanpbx.cfg ?
R2D2
Post by R2D2 »
i also had
in the log.
but no way ...
R2D2
Post by R2D2 »
Hi again,
R2D2
It works !
Post by R2D2 »
Hi all,
got it working with Reynoud sipconfig.txt.
Official alcatel doc "sip phone installation guide" doesn't have the correct variable and section for firmware (1.x).
gigiborro
Post by gigiborro »
same problem with
any idea??
gigiborro
Post by gigiborro »
I need sample config.... But i´ve not privileges to download Reynoud sipconfig.txt.
R2D2
Post by R2D2 »
here's Reynoud sample config file
#         4008EE / 4018EE SIP-Touch sets configuration file               #
#         SIP : 2.00.81 & 2.00.90                                         #
# This example contains all parameters which may be managed via the       #
# config file and is in line with 3AK_29000_0285_PEZZA_17                 #
## Syntax informations :
## All parameters are grouped by sections (the section name is specified
## with the syntax [section1]). The content is UTF-8 encoded
## Each configuration item uses a single line with a "key=value" pattern
## "Key" content starts at the first none-space character and ends with "="
## or " ="
## "Value" content starts at the first none-space character and ends at the
## "\n\r"
## If the value is empty, the terminal should use the default value instead
## Lines starting with "#" will be ignored as a comment
## The items of a list are separated by a ","
[dns]
## The primary DNS IP address HAS TO BE FILLED
## If no DNS, use the SIP proxy address instead
	dns_addr=192.168.178.1
	dns2_addr=
	hostname=fritz.box
[sip]
## Domain name : IP address, FQDN or domain name (see the SIP proxy config)
	domain_name=192.168.178.1
## Primary SIP proxy and SIP registrar settings
## Proxy address : IP address, FQDN or domain name
## Registrar address : IP address, FQDN or domain name (usually, the proxy)
## SIP proxy UDP port : usually 5060
## SIP registrar UDP port : by default 5060
	proxy_addr=192.168.178.1
	proxy_port=5060
	registrar_addr=192.168.178.1
	registrar_port=5060
	outbound_proxy_addr=
	outbound_proxy_port=
## Redundancy settings
## sip_transport_mode_survi : Transport mode in PCS mode
##		    0 = UDP or TCP
##                  1 = UDP
##                  2 = TCP
	proxy2_addr=192.168.178.1
	proxy2_port=5060
	registrar2_addr=192.168.178.1
	registrar2_port=5060
	outbound_proxy2_addr=
	outbound_proxy2_port=
	pcs_addr=192.168.178.1
	pcs_port=5060
	sip_transport_mode_survi=0
	option_timer=120
## Global SIP parameters
## Transport mode : 0 = UDP or TCP
##                  1 = UDP
##                  2 = TCP
## local_rtp_port : RFC3605 is not supported in this release, so
##                  only default value can be used
## PRACK type : 0 = PRACK supported
##              1 = PRACK required
##              2 = PRACK disabled
## Codec settings : 0 = G711 (PCMU)
##                  4 = G723.1
##                  8 = G711 (PCMA)
##                 18 = G729A
	register_expire=3600
	register_retry=300
	local_sip_port=
	sip_transport_mode=0
	local_rtp_port=42000
	local_rtcp_port=42001
	prack_type=0
	preferred_vocoder=8,0,4,18
## SIP authentication.
## Realm : If no authentication, leave empty
## Authentication name : HAS TO BE FILLED
##                       If no authentication, PUT A VALUE LIKE none
## Authentication password : If no authentication, leave empty
	authentication_realm=192.168.178.1
	authentication_name=620
	authentication_password=620
	user_name=620
	display_name=Studeerkamer
## Voicemail settings
## Voice mail URI : directory number of the voice mail
## user name : directory number of the set
## MWI URI : complete SIP URI of the voice mail
	voice_mail_uri=
	message_waiting_indication_uri=
[qos]
## SIP & RTP DIFFSERV : [0,63]
## SIP QOS Tickets : 0 = disable
##		     1 = enable
## SIP QOS Tickets Target : domain name
	sip_diffserv=0
	rtp_diffserv=0
	sip_qos_tickets_enable=0
	sip_qos_tickets_target=
[sntp]
## SNTP server settings (can be OXE or an external server)
## Timezone construction : UT::60:032902:102503
##          GMT delta : 60 = + sixty minutes from GMT time
##          Daylight saving start (mmddhh) : 032902 = 29 March 2am
##          Daylight saving end (mmddhh) : 102503 = 25 October 3am
## The daylight saving settings HAVE to be changed each year.
	sntp_addr=192.168.178.1
	timezone=UT::60:032902:102503
[telnet]
## Password to access the telnet session
	telnet_password=000000
[arp]
## Mode : 0 = ARP spoofing disabled
##        1 = ARP spoofing enabled
	arp_spoofing_enable=1
	arp_spoofing_timer=30
[init]
## For IP Touch with SIP binary in 1.xx, 2.00.10 and 2.00.20, equal or greater than 2.00.81
##     mode 0 = SIP
##     mode 1 = NOE
## For IP Touch with SIP binary 2.00.30 to 2.00.80
##     mode 0 = NOE
##     mode 1 = SIP
	application_mode=0
[audio]
## Tone country : 0 = English
##                1 = French
##                2 = German
##                3 = Italian
##                4 = Spanish
##                5 = Dutch
##                6 = Portuguese
## DTMF type : 0 = RFC2833
##             1 = In-band
##             2 = SIP INFO
## DTMF level / RLR handset / SLR handset / Sidetone handset :
## 0 = 0db, 1 = +3db, 2 = +6db, 3 = -3db, 4 = -6db
## VAD / DTMF feedback / Hearing Aid :
##       0 = VAD not used
##       1 = VAD used
	tone_country=1
	dtmf_type=1
	dtmf_level=0
	dtmf_avt_payload_type=96
	vad=0
	dtmf_feedback_enable=0
	rlr_handset=0
	slr_handset=0
	sidetone_handset=2
	hearing_aid_enable=0
[appl]
## Password to access the administrator menu on the phone (digits only)
## Power priority : 1 = critical
##                  2 = high
##                  3 = low
## Time format : 0 = 24 hours format
##               1 = AM / PM
## Speed dial numbers (first and last name, URI)
	admin_password=000000
	bluetooth_parameters=blue
	remote_forward_code=
	remote_forward_deactive_code=
	power_priority=
	asset_id=
	time_format=
	speed_dial_1_first_name=
	speed_dial_1_last_name=
	speed_dial_1_uri=
	speed_dial_2_first_name=
	speed_dial_2_last_name=
	speed_dial_2_uri=
	speed_dial_3_first_name=
	speed_dial_3_last_name=
	speed_dial_3_uri=
	speed_dial_4_first_name=
	speed_dial_4_last_name=
	speed_dial_4_uri=
[admin]
## Global admin parameters
## Binary polling timer : 10 min - 65535 min (default 480 min)
## Config polling timer : 5 min - 65535 min (default 60 min)
	binary_polling_timer=480
	config_polling_timer=60
	disable_pc_port=0
	activate_vlan_filter=0
gigiborro
Post by gigiborro »
Tanks a lot!!!
with section end variable:
[telnet]
telnet_password=
My 4008 works with my Asterisk
Skullbocks25
Re: 4XX8EE Phones with Asterisk
Post by Skullbocks25 »
Hi Reinoud,
I have the same problem, can you please attach the files again. Because it doesn't exist anymore on this site.
Return to “Asterisk”
