Omnivista 4760 with SIP trunk to gsm gateway
Re: Omnivista 4760 with SIP trunk to gsm gateway
Is the trunk group declared private?
as per 10.jpg the trunk group is not private
diaz are you sure that are codes are not overllaping between carrier ;some times omnivista can not calculate the coste (cost =0 even duration is not equal to zero) when the area code is shared between to carrier under city /country name , i have seen in my side
look same case
i know why because cost is equal to zero becaus same area code for tow different carrier
as ypu remark ars changes the dialled number and same area appears for two carrier
i add the new area with one additional digit 023 1 in the region of real carrier and with cost recalculation
cost is #0 and area name appears
Zero
Post by Zero »
Hi elias_ruiz_diaz,
Sorry Zero, what do you ask about the calculation mode?
This is to give idea on your inquiry, calculation mode (modo de cálculo) gives the following option:
- Duration: round down
- Duration: exact
- Duration: round up
- Cost given by the PCX
- Based on unit
Thanks,
Zero
elias_ruiz_diaz
Post by elias_ruiz_diaz »
tot3nkopf wrote:Is the trunk group declared private?
no it's not declared, it must to be?
elias_ruiz_diaz
haroun wrote:as ypu remark ars changes the dialled number and same area appears for two carrier
in the first two screenshots (that you upload) it doesn't cost the call, but in the second two, they work.. what did you change? I didn't undestand that part..
Thanks!
elias_ruiz_diaz
Zero wrote:Hi elias_ruiz_diaz,
- Duration: exact
- Based on unit
Thanks,
Zero
my calculation mode is "Duration: exact" I also tried with "Duration: round up"
joao.carlos
Post by joao.carlos »
Can you post NMC_CostCalculation.log ? Just the lines regarding the number that the cost =0
elias_ruiz_diaz
joao.carlos wrote:Can you post NMC_CostCalculation.log ? Just the lines regarding the number that the cost =0
I only have "NMC_CostRecalculation_1.log" I didn't find "NMC_CostCalculation.log"
Return to “OmniVista 4760”
