Alcatel 4400 to Cisco via PRI
stamatovs
Re: Alcatel 4400 to Cisco via PRI
Post by stamatovs »
How can I understand/view if there are some automated processes in the system? My goal is to understand if there are scripts or something like that or some default process that is able to update my parameter. I have mtcl account. How can I check schedule of automatic tasks.
Thank you!
It is a linux, so a cron should be working, but, we are talking about messing with OXE DB, which is a non linux task, and to be extremely flexible to know all new trunks you create? I seriously doubt it...if that was the case all your trunks should be affected.
Open an eSR with ALU or upgrade to last patch.
stamatovs
Post by stamatovs »
There is schedule only for archive. I tried to configure new BRI interface and when I created TG "Nb of digits unused" was 0 by default and remained 0. For this TG the value is not changing and there are no updates from <MANAGER|> in maohist. For my PRI I still have this issue.
If you create two PRI TG (and allocate access only to one TG) - number of unused digits changed? In both TG?
Return to “ON SITE TROUBLES”
