SIP Congestion
Re: SIP Congestion
SEE SYSTEM public network service/ numbering conversion
or post you own trunkg config including npd selector for that trunk
idem for npd at translator /external dial plan /npd
ranjithvkumar
Re: SIP Congestion
Post by ranjithvkumar »
When i am creating NDP with
│ Install. number source + NPD source │
│ Default number source + NPD source │
i am getting error message that "Called DID identifier: Invalid operation: reserved NDP for automatic mode"
How can i fix this?
ranjithvkumar
Re: SIP Congestion
please find the configuration in the attachment.
Re: SIP Congestion
AND WHAT's youristallation number and did range i see that you areusing 10 digits for that wich s to much,did digits number must be at max 4digits?
for exemple 0165299201 is TRANSLATEd TO?
in genral way
istallation number according to range buyd 0101652992 (100 DID) or 0165299(for more)
200 or 9200 is default suppl inst number --attandnat one
to deactive autmatic mode just unselect at trunk np selelctor and change it to manual or expert , or config istallation number +supp int number at entity level entity 0(trunks entity) and entity 1(users entity) as mentionned in the npd number 10
perform didtest command
1
g
0
2
(1)pst_cpu20> didtest
Wed Mar 4 13:43:59 CET 2015
0 : exit
1 : select did
2 : incoming did
3 : outgoing did
4 : view selected did data
5 : view selected did data order by internal number
6 : exec time
choice : 1
general did or public overflow : [g]/p g
did id : <0..99> : 2
choice : 2
external number : 2000
sda partiel :
DID_FOUND
(dicho) DID_FOUND
sda : found internal number : 51009
sda : found internal number(dicho) : 51009
0 : exit
1 : select did
2 : incoming did
3 : outgoing did
6 : exec time
choice : 3
local number : 51009
found external number : 2000
found external number (dicho) : 2000
0 : exit
1 : select did
2 : incoming did
3 : outgoing did
6 : exec time
choice :
ranjithvkumar
Re: SIP Congestion
It says
NOT FOUND
no corresponding internal number
for both incoming DID & outgoing DID i am getting above mentioned result.
ranjithvkumar
Re: SIP Congestion
My service provider say that my server sending "484 Address Incomplete" error message. may i know what may be the reason ?
Re: SIP Congestion
for did try to change external number to 9200? or 200 fullfill installation number +supl installation at your extension entity and see if change happens
for out going i see that you are receiving 484 check the dialled number ,This cause indicates that the called party cannot be reached because the called party number is not in a valid format or is not complete.
Re: SIP Congestion
Deactive overllaping dial
dryhouse
Re: SIP Congestion
Post by dryhouse »
Hi ranjithvkumar,
You must configure in your OXE --> external Gateway SIP the domain IP, 172.29.67.10.
In our ISP is necesary to do it.
Try to do it and good luck.
ranjithvkumar
Re: SIP Congestion
Hello Dryhouse,
Now the packets are exchanging between the servers. But DID is not working, thats what i am trying to fix it with the help of experts here.
Return to “SIP”
