can you share to us the files to copy to tftp root folder, can you also share to us the file for sip config.
thanks,
[/quote]ahmedfahmey wrote:Dear All
sorry for beeing late
to update your iptouch 4018 follow the following steps
1- prepare a cross cable
2- install a tftp server ( i used solarwinds tftp server )
3- copy all files to the tftp root folder
4- edit the sipconfig file
5- configure your set ip parameters
6- change restrict vlan to "no"
7- change vlan to your vlan
8- change tftp server 1 & 2 to the pc ip ( tftp server ip )
9- restart your set ( you will see that it's updating )
10- after doing that turnoff the set then connect it to computer by cross cable
11- start the set in industrial mode by holding ( i + 1 + 2 + 3 ) while starting the set & release all buttons when leds lights
12- set your pc ip to 192.168.1.6
13- telnet 192.168.1.1
14- type "verswitch" then press "Enter"
15- restart the set
16- while restarting press ( i + # ) to enter configuration mode
17- go to software info
18- now you can change NOE to SIP
19- after changing to SIP restart the set after connecting normally to your network with the permanent network settengs
20- make sure that your tftp server is working & all files are in the tftp root folder
i think it's ok now set updated & you can connect iptouch to freepbx or any SIP pbx
