If I boot the vm with Linux ISO. Linux is properly installed in vm. I mounted the oms ISO in the Linux and tried to run with root user in Linux but it's not running the setup/installation of OMS.
So to be more clear , let me tell u in this way
We are discussing on two senerios,
1. Installation of Linux and oms in vm with Aled
2. Installation of Linux in vm and oms with out Aled.
So now can u guide further.
Oxe media server OXE MS installation in a VM
Re: Oxe media server OXE MS installation in a VM
hmm... i prefer installation witout aleds and virtualbox for testing purposes
so i've checked point 2 (installation without aleds) with the actual iso-files from bwps.
conclusion -> it works without any error message...
what i've done:
1. creation of a new virtual machine in virtualbox (with default values for redhat64bit linux)
2. insert image bootdvd.6.4.010.008.x86_64.iso in virtual cdrom drive
3. switch on the virtual machine and install linux (german/german keyboard/timezone Europe/Berlin/Systemtime in UTC)
4. login first time -> give the ip-address/subnetmask/dns-server and default-gateway)
6. insert the image oms-3.06-IP0001.iso in virtual cdrom drive
7. mount the cdrom (mount /dev/cdrom)
8. start the oms installation (cd /media/cdrom; ./oxe_media_server-launcher.bin -console)
9. after installation mgconfig can be run...
used versions (with md5 checksum infront):
24ccc0bae9d4f01b3b4103ec570320dd bootdvd.6.4.010.008.x86_64.iso
47474841c3cf37e1717572a65ba9be1b oms-3.06-IP0001.iso
regards and good luck...
what i've done:
cccengg
HI Dear TGN
nice detailed info .. i will check it now ,, and will let u kmow the results...
one thing to be more precise
ip= 10.1.1.2
sub =255.255.255.0
Gateway = CS address
dns=CS address
Is this okey
ip= 10.1.1.2
sub =255.255.255.0
dns=CS address
Is this okey
cccengg
how to get rid of this error in OXE VM
can not open file /proc/sys/net/ipv4/conf/eth0/accept_redirects
My eher net is not showing in the ifconfig command
Which VM are you using? VMWARE desktop? Which version?
ip and subnet mask must fit the network parameters of the subnetwork.cccengg wrote:
ip= 10.1.1.2
sub =255.255.255.0
dns=CS address
Is this okey
Gateway should be the default Gateway of your network. you can put in your cs address, if you have no need to reach another subnet than your own.
dns should be your domain-name-system server. i think it's not really needed, since oms is configured with ip-addresses. you can put in the cs address as a "placeholder". but hold it in memory the cs is not a full functional dns server (even if dns is activated by netadmin in cs).
regards...
which network adapter type did you choose in the vm? it should be e1000 when vm type is other linux 32bit.cccengg wrote:how to get rid of this error in OXE VM
regards...
cccengg
HI Tqntgn wrote: ↑04 Apr 2017 09:55 hmm... i prefer installation witout aleds and virtualbox for testing purposes
what i've done:
some how i manage to install the OMS
Really thanks for you help in this regards.
what i did is .....
Installed the Linux in vm then installed the yum install java, then mount the cdrom anf run the OMS...it goes through.
cccengg
HI Tgn
how to get OMS in service ,, i tried to run rstcpl 3 0 ,, but i gives me this error
Error photos and other information is attached.
things to note.
vm of oxe was installed as blade server.
oxe vm had the licensing for OMS.
how we can make OMS in servise in OXE VM.
things to note.
