I made some progress today. The error in my configuration was the lack of setting OXE ip address. Not sure exacty the order of steps to deploy the server and learning as i go.
1. I used swinstall to drop db and create empty db
2. then I restored my oldest database
3. I set the PC A4740 address
4. Set new internet address and now the webui is accessible.
5. I restored OPS
6. turn autoset to on
7.
I saved my CS terminal output for future reference.
I still have some learning all these install scripts but so far I think im unblocked.
So now when i netstat -an I get port 443 for OXE webui administration.
(1)xa000000> netstat -an
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 0.0.0.0:5060 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:2565 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:2533 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:2535 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:2569 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:2539 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:2540 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:2574 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:2576 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:2577 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:2579 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN
tcp 0 0 10.80.212.87:443 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:2555 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:2535 127.0.0.1:10449 ESTABLISHED
tcp 0 0 127.0.0.1:10449 127.0.0.1:2535 ESTABLISHED
tcp 0 0 127.0.0.1:10241 127.0.0.1:2535 ESTABLISHED
tcp 0 0 127.0.0.1:2535 127.0.0.1:10241 ESTABLISHED
udp 0 0 10.80.212.87:123 0.0.0.0:*
udp 0 0 127.0.0.1:123 0.0.0.0:*
udp 0 0 0.0.0.0:123 0.0.0.0:*
udp 0 0 0.0.0.0:2556 0.0.0.0:*
udp 0 0 10.80.212.87:32640 0.0.0.0:*
udp 0 0 0.0.0.0:2570 0.0.0.0:*
udp 0 0 0.0.0.0:12300 0.0.0.0:*
udp 0 0 10.80.212.87:5060 0.0.0.0:*
udp 0 0 0.0.0.0:5060 0.0.0.0:*
udp 0 0 0.0.0.0:69 0.0.0.0:*
Active UNIX domain sockets (servers and established)
Proto RefCnt Flags Type State I-Node Path
unix 2 [ ACC ] STREAM LISTENING 10658 /var/run/acpid.socket
unix 2 [ ACC ] STREAM LISTENING 13148 /var/run/nginx_socket
unix 2 [ ACC ] STREAM LISTENING 13150 /var/run/dm_socket
unix 10 [ ] DGRAM 10708 /dev/log
unix 3 [ ] STREAM CONNECTED 13155
unix 3 [ ] STREAM CONNECTED 13154
unix 2 [ ] DGRAM 13111
unix 2 [ ] DGRAM 12082
unix 2 [ ] DGRAM 12081
unix 2 [ ] DGRAM 11066
unix 2 [ ] DGRAM 10961
unix 2 [ ] DGRAM 10933
unix 2 [ ] DGRAM 10745
unix 2 [ ] DGRAM 10737
unix 2 [ ] STREAM CONNECTED 10667
unix 2 [ ] STREAM CONNECTED 8968
(1)xa000000>
OmniPCX Enterprise - Troubleshooting
testuser123
Re: OmniPCX Enterprise - Troubleshooting
5. I restored OPS
7.
(1)xa000000>
5. I restored OPS
7.
(1)xa000000>
