8001 phones are not coming UP
Re: 8001 phones are not coming UP
I made a backup via IC BIOS(Firmware copy) and copied it to the problem phone, but the problem was still not solved
yaser-motiee
Hello
I need these files
"kernel and application"
please send to my Email.
yaser_motiee@yahoo.com
I need these files
yaser-motiee
Hello my friend.
I need "kernel and application" for flash Alcatel ip-phone desktop 8001.
Can you share me the kernel and application.
thanks
Could you please share with me latest kernel and firmware for 8001?
skipper.com@gmail.com
Many thanks in advance!
- frank
Either you changed something on your data switch where the PoE is not sufficient anymore.
Or you changed something in the network a while back, never saved the conf in your switches, rebooted, and lost the conf.
I suggest you take 1 phone on a single data switch to remove the PoE issue, and configure this one switch correctly with dhcp helper if you are using the OXE/OXO has DHCP Server.
em 2024 , alguém tem alguma solução para o problema recorrente dos aparelhos Alcatel 8001
Iridintelligence
Problem solved , the sip 8001 is Chinese deskphone commercialized by alcatel , "es290" of "ascene" , the problem is in hardware , replace two capacitors C9 and C17 were through-hole aluminum electrolytic capacitors. replace both electrolytic capacitors(C9, C17) to SMD(Surface Mount Device) capacitors with the following parameters.
SMD capacitor parameters:
0805/22uF±20% 6.3V X5R,
Then you can update it to the latest version of app 4.5.0.7 and kernel 3.0.5 , you find it in attachments
yaser-motiee
************** Thank you my friend **************Iridintelligence wrote: ↑14 Oct 2024 04:08 Problem solved , the sip 8001 is Chinese deskphone commercialized by alcatel , "es290" of "ascene" , the problem is in hardware , replace two capacitors C9 and C17 were through-hole aluminum electrolytic capacitors. replace both electrolytic capacitors(C9, C17) to SMD(Surface Mount Device) capacitors with the following parameters.
The software doesn't have Chinese language support. Are there any software options with Chinese language support? Where can I obtain them? Thank you.
