SIP Failed for OXE and Avaya IPO 500
mgsox
Re: SIP Failed for OXE and Avaya IPO 500
Post by mgsox »
hi try to disable Round Trip Delay Request under >> mgr>IP>IP Parameters
mgsox
Post by mgsox »
poposami wrote: 27 Aug 2020 14:24 OXE-AVAYA SIP call disconnect after 31 seconds.pdfWe are facing outgoing calls disconnection from oxe to Avaya after 31 seconds.
Whereas calls from Avaya to OXE R12.2 are okay.Below is call flow where oxe does not acknowledge 200 OK sdp from Avaya
and eventually releases call with bye from Avaya.
I would appreciate suggestions ASAP as customer is very upset.
kimy
Post by kimy »
vad wrote: 31 Aug 2020 00:01 You have nothing in motortrace?
Show trkstat output.
@ vad, trkstat and motortrace.Please help me analyze.
There're no calls in the traces only registration message but i saw two message
488 error code so check the codecs offer
sipexgw=-3?! strange can u paste the local and extgw config
when u made call from oxe u got immediatly hung up? try to capture a trace while calling
kimy
Post by kimy »
haroun wrote: 01 Oct 2020 08:50 There're no calls in the traces only registration message but i saw two message
Hi haroun,
here are the the extgw config:
when i made i call it says "Request Terminated" after 2 rings
what's ur system default codec ?
what's the trunk group 2 codec type ?
looks like the codecs are mismatch
fegysimon
Post by fegysimon »
could you have a check on the codecs enabled @ Alcatel side and Avaya side is matching or having a common codec selection to agree upon.
Normally the SDP session fails if there is no common codecs at both sides.
./regards
Fegy Simon
morio
Post by morio »
hi, hope you have resolved your problem. cus i have the exact issue as well. can you help or let me know what was the issue? thanks.
morio
Post by morio »
