OXE sip trunk reply 404 rejected/not found here
sadim
Re: OXE sip trunk reply 404 rejected/not found here
Post by sadim »
Try to change the parameter "Loose Route with RegID" under system, other system params, SIP parameters
morio
Post by morio »
hi sadim
done "Loose Route with RegID" and even given a reboot, still the same
Is 1941 ISR making NAT?
morio
Post by morio »
hi guys,,,
got it sorted out, the provider needed to get some stuff corrected. when they re configured their side everything worked fine,,
ALE tac gave me few recommendations during that time. but then the provider sorted the issue.
thanks to all who tried to sort the problem and gave me in some ideas to work about...
nice to know that it works for you and the issue is closed .
we will appereciat if you share with us what was the solution
thanks in advance
morio
Post by morio »
morio
Post by morio »
hi guys,
i have attached a copy of the ok and not ok trace cap of the invite. hope it will be useful to you all. and thank you for all who gave their best to trying to resolve this issue. take care and Marry Christmas to all....
Morio
Hi Morio and thank u very much for sahring
the strange route header was the first thing that takes my attention it was oute: <sip:+966115051030;tgrp=320_grpMain_tgrp;trunk-context=itc.sa@sa-Hilton.Riyadh:5060;lr>
with trunk group context i think the 1941 can't handle them
Return to “SIP”
