Install R100.1 in vmware or virtualbox
Skoh_utec
Re: Install R100.1 in vmware or virtualbox
Post by Skoh_utec »
haroun wrote: 05 Oct 2023 21:15 can u type any command ike netadmin
Yes, seems netadmin is able to run.
ifconfig is NG.
Skoh_utec
Post by Skoh_utec »
oldboy wrote: 05 Oct 2023 21:31Try 5.6
Thank you let me try.
Skoh_utec
Post by Skoh_utec »
Sorry, my mistake. Actually using ver5.6 now.
Skoh_utec
Post by Skoh_utec »
oldboy wrote: 05 Oct 2023 21:20 In the syslog it is complaining re dhcp lease no free addresses which is strange, the linux looks fine.
Have you tried just the base instead of the full version ?
Yes, tried base installation but had same issue.
Skoh_utec wrote: 05 Oct 2023 21:33
ifconfig is NG.
after installing the static release from that make the necessary change for machine name (netadmin-m)and reboot
swinst and check and install the patch and delivries
cuze i got same message at pc installer with cpu 6 but was surprised that linux + swinst + tel were good and i continued the with patches installations as usual . system is runing now and with no errors or incident
Return to “Other”
