checkdb : ERROR 4351 : DATA INCONSISTENCY
DjeSan
Re: checkdb : ERROR 4351 : DATA INCONSISTENCY
Post by DjeSan »
haroun wrote: 12 Oct 2023 11:58 ok the npd used is N°2
go to translator/external numb plan/ Numbering Plan Description (NPD) select N°2 and see what 's the config and especialy the did
e Number (reserved) : 1 x
x Instance (reserved) : 1 x
x Description identifier : 37 x
x x
x Name : * x
x Calling Numbering plan ident. + NPI/TON ISDN National x
x Called numbering plan ident. + NPI/TON: ISDN Unknown x
x Authorize personal calling num use + False x
x Install. number source + Entity source x
x Default number source + None used x
x Called DID identifier : 4 x
x Calling/Connected DID identifier : 4 x
x
fater that chek what's on your did under ID number translator rule
hello when i try to configure the different sections i get an error message
""Modification \SiegeTraducteur::1Plan de numérotation externe::1NDP.::2
Origine num. installation : Invalid operation : NPD reserved for automatic mode""
haroun wrote: 12 Oct 2023 12:11 and i see in the trace that used npd used is from trunk group 10
so go
trkgp /go down in hierarchy/trunk group NPD selector and past what's th econfig for the trkgp 10
here's the trkgp 10 config
Consultation/Modification: Passerelles Externes──────────────────────────────────────────┐
│ No noeud-r▒seau (r▒serv▒ soft) : 0 │
│ Instance (r▒serv▒e soft) : 1 │
│ Instance : 10 │
│ Nom de la passerelle : GATEWAY SIP │
│ Domaine distant : 131.107.3.246 │
│ Adresse IP PCS : ----------------------------------------------- │
│ Num▒ro de port : 5060 │
│ Type de transport + UDP │
│ Domaine d'appartenance : -------------------------------------------------- │
│ Id d'enregistrement : -------------------------------------------------- │
│ Id d'enreg. dans P_Asserted + Non │
│ Timer d'enregistrement : 0 │
│ Proxy : -------------------------------------------------- │
│ Timer de supervision : 0 │
│ Num▒ro de faisceau : 10 │
│ Num▒ro de pool : -1 │
│ Domaine sortant : -------------------------------------------------- │
│ Nom de l'utilisateur sortant : -------------------------------------------------- │
│ Mot de passe Sortant : -------------------- │
│ Confirmer : -------------------- │
│ Nom de l'utilisateur entrant : -------------------------------------------------- │
│ Mot de passe entrant : -------------------- │
│ RFC 3325 support▒ par le distant + Non │
│ Type de DNS + DNS A │
│ Adresse IP du DNS primaire : ----------------------------------------------- │
│ Adresse IP du DNS secondaire : ----------------------------------------------- │
│ SDP dans 18X + Non │
│ Authentification minimale + Aucun │
│ M▒thode INFO pour remote extension + Non │
│ Envoyer uniquement algo faisceau + Non │
│ Vers EMS + Non │
│ SRTP + RTP │
│ Application de routage + Non │
│ Ignorer inactive/black hole + Non │
│ Contact avec adresse IP + Non │
│ Type de payload dynamique (dtmf) : 97 │
│ 100 REL pour les appels sortants + Support▒ │
│ 100 REL pour appel entrant + Non demand▒ │
│ Type de gateway + Type standard │
│ Re-Trans No. for REGISTER/OPTIONS : 2 │
│ P-Asserted-ID dans No Appelant + Non │
│ Ent▒te P-Asserted-ID certifi▒ + Oui │
│ Info. de renvoi ext. fourni par + History Info │
│ Sp▒cialis▒ d▒part + Non │
│ Relai SDP sur renvoi ext▒rieur + Default │
│ Ent▒te From certifi▒ + Non │
│ Supporte le Re-invite sans SDP + Non
hi
i asked only to past the npd config by reviewing it (choose review\modifie)
up is not the trkgp but externaL GW config go to trunk group / go down in hierarchy (descendre en hierarchie) / selection du npd / review modified pour le trk gp 10
AND WHAT HAPPENS IF YOU CHANGE DDITRANSCODING TO YES IN THE TRKGP GIVE IT A TRY
DjeSan
Post by DjeSan »
haroun wrote: 13 Oct 2023 08:53 hi
sorry but I don't understand
is the ndp in entity or not?
please tell me where to find the trunk group section i can't find it
is the trkgp configuration in the sip or ip section?
DjeSan
Post by DjeSan »
DjeSan
Post by DjeSan »
when this option is activated and I make a call I get an error message telling me that the number doesn't exist
when this option is deactivated, I don't get any error message; when I launch the call, it cuts off directly
DjeSan
Post by DjeSan »
the problem was in the connection category someone had modified it
Return to “System”
