INT-IP2 card not work
doublevand981
Post by doublevand981 »
(1)viscohn> cdmao
/DHS3data/mao
(1)viscohn> touch lanpbx.cfg.old
(1)viscohn> lanpbxbuild -auto
Fri Jul 2 12:48:42 CEST 2010
IP CPU 1: 192.168.1.100
Are you sure (Y/N):y
Renaming /DHS3data/mao/lanpbx.cfg to /DHS3data/mao/lanpbx.cfg.old
Permission denied.
Permission denied.
Permission denied.
Try "lanpbxbuild" (not lanpbxbuild -auto)
lanpbxbuild, add, enter tftp server address, add current line, main menu, apply.
And system restart.
doublevand981
1)viscohn>
Fri Jul 2 14:54:20 CEST 2010
No previous lanpbx.cfg file.
1. View
2. Add
3. Delete
4. Modify
5. Move
6. Apply changes
7. Copy lanpbx to lanpbx-mipt
0. Quit
==> 2
1. View all lines
2. Download IP (TFTP Server)address ( required )
3. Download IP RD(TFTP Server)address ( none )
4. Alternate TFTP port ( none )
5. CPU 1 IP address ( none )
6. CPU 2 IP address ( none )
7. SSM 1 IP address ( none )
8. SSM 2 IP address ( none )
9. Bin Download IP (BIN TFTP Server)address ( none )
a. Add current line
c. Clear current line (no confirmation asked)
0. Back to main
==> 2
Enter TFTP Server IP address (ex:a.b.c.d or 'Q' to abort) : 192.168.1.100
1. View all lines
2. Download IP (TFTP Server)address ( 192.168.1.100 )
a. Add current line
0. Back to main
==> a
1. View all lines
a. Add current line
0. Back to main
==> 0
1. View
2. Add
3. Delete
4. Modify
5. Move
6. Apply changes
0. Quit
==> 6
Permission denied.
Permission denied.
1. View
2. Add
3. Delete
4. Modify
5. Move
6. Apply changes
0. Quit
==> 0
cdmao
more lanpbx.cfg
once again please. if this shit does not work, you'll write the file by hand.
doublevand981
Hi frank,
i created and system till not work. pls see attached file for long resutls.
Try the lanpbxbuild -auto now that you created it.
If it does not work, try
cdmao
rm lanpbxbuild.cfg*
lanpbxbuild -auto
doublevand981
Hi frank,
still failed
not permission
hi.
When can we do a remote session ?
What time zone are you in ?
doublevand981
i am in vietnam . timezone +7
pls let me know when you can remote to help me?
thanks so much
mysticalself
Post by mysticalself »
I think you can reload the linux and check. Reload the linux and restore the mao. Ignore if you have already tried it :)
Return to “IP”
