check your database
thkim81
Re: check your database
Post by thkim81 »
(1)kmccs_a> checkdb
Data base checking in progress ...
/................ERROR 4351 : DATA INCONSISTENCY, Table ENTITY, entity=0 invalid cdt
ERROR 4351 : DATA INCONSISTENCY, Table ENTITY, entity=1 invalid cdt
Is this ok ?
I indicated incvisu below error
21/02/12 17:16:11 000001S|---/--/-/---|=2:2651=SQL err during a FETCH: appli ACCOUNTING table TABJUSTIF err 0
this error is major error ..
How do I check db part ?
Checkdb - check you database, on MAIN cpu!
Incident - from stand-by cpu - run checkdb on stand-by. Or better - run mastercopy.
thkim81
Post by thkim81 »
thanks vad
Today I check active and standby oxe server.
so yesterday error didn't found. it seems that delete.
today is below..
(1)kmccs_b> checkdb
this logs are indicated active and standby
is that OK?
I think this log about entity.. That's right?
murraya
Post by murraya »
hi, those errors are stating that entity 0 and 1 have either missing or incorrect numbers in the call distrubition tables.
to stop them you will need to fill in the Day, Night, Mode 1, Mode 2 and overflow fields.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
I think he has also databases not synchro between CPU's. He has another post with this. I suggested like vad did to rebiold netadmin and do a mastercopy.
Return to “Usefull commands”
