Omnivista 4760 with SIP trunk to gsm gateway
Re: Omnivista 4760 with SIP trunk to gsm gateway
HI
what i mean : there is same prefix for two carrier 0239 exist as a region under carrier 1 and same for carrier 2 , omnivista witch stronge can't make diffrence as it calculates cost on basis of the region so when it see same area for two carrier cost is null . tomake a diffrence i add a dialed digit under second carrier (as the call is routed under him) , and cost recalculation fix the issue , but this way do not satifie me omnivista should make difference based by the taken route
what i sugget you create the whole prefix 097 plus the digit 2 and 098 plus digit 1 under the traget region and make a cost calculation from account /trafic compute cost marke the 3 last case, and if cost is here.
for log file search for
root:\4760\log
NMCLD_costcalculation
for my case i found under the log file that there is no first carrier (confusion)
Zero
Post by Zero »
Hi elias_ruiz_diaz,
Have you considered setting the calling region (for verification)? What's the outcome?
Thanks,
Zero
elias_ruiz_diaz
Post by elias_ruiz_diaz »
Zero wrote:Hi elias_ruiz_diaz,
Thanks,
Zero
Continue being cost=0 :(
Zero
Post by Zero »
Hi elias_ruiz_diaz,
Having that said, I anticipated that you had setup all your carriers with the calling region parameter. In any case you may find it helpful; viewtopic.php?f=371&t=20377&p=72664&hil ... ost#p72664
To verify your data, kindly take note the value of carrier as you access Interactive SQL. Try to compare two records (one with cost; one without cost). Please refer on link, viewtopic.php?f=274&t=20042&p=71814&hilit=cost#p71814
Thanks,
Zero
joao.carlos
Post by joao.carlos »
Yes, that's it. I was using my phone and didn't remember the exact filename.
elias_ruiz_diaz
Thanks,
Zero
Hi, I did that, and step by step, one and another time. Talking about a the interactive SQL, i don't understand much about what you mean with this, what you say i have to do with the SQL interactive? (i've never used SQL)
luis.molinas
Post by luis.molinas »
Hi Elias,
How you have configured the "Carrier Reference" in the OXE on "Numbering Command Table"? try to change to "0" and cost calculation will make the OV4760.
Tell me about your progress!
Good luck!
elias_ruiz_diaz
Yes Luis, the case is solved! thanks! :)
Return to “OmniVista 4760”
