doublevand981
Shot me a private message with your email
INT-IP2 card not work
robersan
I'm trying to find out the syntax to be used when generating manually (not using lanpbxbuild) a lanpbx.cfg file which deactivates the requirement for security into the IP touch phones. I guess it could be resetting the SSM IP addresses (IP_SSM1 and IP_SSM2?) but I'm not plenty sure about that so I'd like to see a complete (with all parameters) lanpbx.cfg configuration text file to check the format.
Thanks in advance.
Thanks in advance.
prasanna_s3
I got some similar problem, doesn't start INTIP2 as INTIPB connected to some Cisco switch gigabit port, a lot of errors on connection.
It was tried to manage fixed 100 full or auto speed, doesn't help.
Few boards works, one - not.
I found that doesn't work board, which has:
Boot/download version : intip _06.10 _29Aug08_15h03
Others boards has Boot/download version : intip _06.08 _26Mar08_10h26
I have tried to attach board to OXE R9.1 and later back to customer R7.1 patch 35, all boards reloads with 6.08, apart this one with 6.10.
We are planning to migrate to R9.1 patch 21 and I am afraid that some INTIPB will reload with BOOT 6.10 and will not be able to connect with Cisco switch.
All Cisco swith ports are managed 100 full duplex.
Have anybody experienced something similar?
Problem solved.
It was switched on CHQoS on INTIP2 - VLAN,...
More simple Cisco 100Mbps switch not reacted on that, but redislocation on customer site was done to Cisco C3560G.
Just switched off QoS and thats all.
Problem solved.
