SIP Congestion
mustafa.ahmad
Re: SIP Congestion
Post by mustafa.ahmad »
Hi Ranjith,
You will need to install an SBC router with NAT configured to translate your Call server IP address to the STC SIP Server IP .
Attached is the sample of that configuration, for one of the sites configured for STC
Re: SIP Congestion
Thanks Mustafa for sharing .that was a suggestion at the beggining.
even that signaling is working well but rtp are not if he posts wireshark we can state why , portsdue to firewall,sbc or some config missed at oxe
mustafa.ahmad
Re: SIP Congestion
Sorry , I saw the later messages now only. It's working it seems. Only incoming is the problem .
wagash
Re: SIP Congestion
Post by wagash »
Dear Mustafa,
Did you solve the incoming issue? I have a similar problem too. Share if you solved it.
Return to “SIP”
