Virtual 7750 SR Available in 12.0.R4
dudepro
Re: Virtual 7750 SR Available in 12.0.R4
Post by dudepro »
Is there any way to upgrade the image without having to install a new VM?
TIA
Stoffen
Post by Stoffen »
dudepro wrote:Is there any way to upgrade the image without having to install a new VM?
TIA
If you load your image from external, you can change the version and config file during boot.
My BOF file looks like this
A:P1_SR01# show bof
BOF (Memory)
primary-image ftp://*:*@10.191.129.2/./both.tim
primary-config ftp://*:*@10.191.129.2/./configs/pod1/SR01.cfg
address 10.191.129.11/24 active
static-route 10.0.0.0/8 next-hop 10.191.129.1
autonegotiate
duplex full
speed 100
wait 3
persist off
no li-local-save
no li-separate
console-speed 115200
To extract the software, you need to create a new VM, and upload the image to your FTP server, or perhaps convert the .qemu2 file to something that is possible to open with some sort of ISO software and copy it from there.
[flash=]
Christoffer
Network System Expert Norway
Nokia SRA #265
Cisco CCNP Certified
LinkedIN
[/flash]
thecandymancan
Post by thecandymancan »
Handy script to save your configs automagically. I've set this to 1680 seconds, so every 28 minutes.
A:P2# configure cron
A:P2>config>cron# info
script "SAVE_CONFIG"
description "Save configuration"
location "cf3:/SAVE_CONFIG"
no shutdown
exit
action "SAVE_CONFIG"
results "cf3:/SAVE_RESULTS"
no shutdown
exit
schedule "SAVE_CONFIG_28"
interval 1680
no shutdown
exit
A:P2>config>cron# /file type SAVE_CONFIG
File: SAVE_CONFIG
/admin save
A:P2>config>cron#
srikandiduduk
Post by srikandiduduk »
My QEMU doesnt run while I run more than one router at GNS3. Anyone know the cause and how to slove it ?
rshdmamun
Post by rshdmamun »
It can be run easily in GNS3. Just use the latest version of GNS3 and config the QEMU from GNS3. For me, if i set memory = 1024 MB only then the virtual 7750 SR can be booted. Other values fail me every time. But the real problem is "rebooting". For me just after 1/2 minutes the virtual 7750 SR reboots again. Is there any solution for this? Or its just memory problem?
thecandymancan
show system licence will tell you how much time is left before the reload. If it says 60 minutes at bootup time but it crashes then your problem is elsewhere I would think
rifster
Post by rifster »
FYI. ALU recommends 4096mb per one VM but this is most likely to support most features at once. I use to assign 2048mb but recently I ran into insufficient memory warnings when I had OSPF, OSPFv3, MPLS (LDP+RSVP) and some L2 services running simultaneously. The router barked at me when I wanted to enable MPBGP for VPRNs. I assigned 2560mb and it turned out to be enough.
didigno
Post by didigno »
2048 MB per each VM is fine for me. I run GNS3 with Mac OSX 10.9.5 Mavericks. So far I did not try Multicast but all the rest is working fine.
mjohans
Post by mjohans »
I'm trying to setup two SRs with MC-Lag, but for some odd reason it just wont work. Anyone got this to work? When the link between them is no shutdown, the lag in both machines are in standby, if I disconnect the cable, both are active.
I'm using gns3 1.2.3
I can ping between them, OSPF works, MPLS works and I can LSP ping between them. MC-Lag is up and running
Multi-Chassis MC-Lag Peer 192.168.0.2
Last State chg : 02/05/2015 12:07:28
Admin State : Up Oper State : Up
KeepAlive : 10 deci-seconds Hold On Ngbr Failure : 3
Lag Id Lacp Remote Source Oper System Id Sys Last State Changed
Key Lag Id MacLSB MacLSB Prio
1 1 1 Def n/a 00:1a:f0:00:00:03 1 02/05/2015 12:08:02
Number of LAGs : 1
but the lag is down
Lag Data
Lag-id Adm Opr Weighted Threshold Up-Count MC Act/Stdby
1 up down No 0 0 standby
Total Lag-ids: 1 Single Chassis: 0 MC Act: 0 MC Stdby: 1
some config:
A:SR7_1>config>redundancy>multi-chassis>peer# /configure port 1/1/2
A:SR7_1>config>port#
A:SR7_1>config>port# info
ethernet
mode access
encap-type qinq
speed 100
no autonegotiate
exit
no shutdown
A:SR7_1>config>lag# info
mode access
encap-type qinq
port 1/1/2 priority 1
lacp active administrative-key 32772
no shutdown
A:SR7_1>config>redundancy>multi-chassis>peer# info
mc-lag
lag 1 lacp-key 1 system-id 00:1a:f0:00:00:03 system-priority 1
no shutdown
exit
sync
igmp-snooping
srrp
sub-mgmt ipoe
port lag-1 sync-tag "lag-1" create
exit
no shutdown
exit
no shutdown
anyone got a clue? A theory I have is that both have the same base mac address, and that somehow fucks it up, but I don't know.
mjohans
Post by mjohans »
Has anyone got MC-Lag to work using the Virtual SROS? I can get OSPF, MPLS to work and the MC-Lag is up, but the lag is standby in both machines. If I turn off the port between them, both go in active mode.
I've tried gns3 v1.2.3, as well as the virtual manager program using the xml files to build the links between them, no difference.
Return to “7750 SR”
