AA issue
marlon74ph
AA issue
Post by marlon74ph »
hi,
I have rel 4.1 oxo and AA open license.
I programmed my vm port to hunt group 540, dialing "0" from external works fine (AA menu answers), my problem is when i dial "0" internally my AA answers... does it works this way?
thanks.
mpr
What is 0 in your numbering plan? If a call to the HG, why should it work different from external to internal?
steve
Post by steve »
If you want to use the VoiceMail ports as Autometed Attendant, then You must put them into the Attendant group !
(and call the attendant prefix internally instead of hunt. grp. number)
marlon74ph
cavagnaro,
"0" is operator, i'm wondering why, it should go my operator when i dial 0 internally, should i miss something?
Steve,
ok, ill just tell my client to call internal prefix then.
what if i want to use at AA only... how will i program...??
tnx guru's
marlon74ph
cavagnaro,
"0" is operator, i'm wondering why, it should go my operator when i dial 0 internally, did i miss something?
Steve,
tnx guru's
steve
Post by steve »
Do you want to use a "Human Interface" as attendant ?
If no: Just put the voice mail ports into the attendant group (don't forget the Time Ranges), and set up the autameted attendant menu and voices.
marlon74ph
steve,
No Human Intervention, Thanks i'll do that
mpr
If 0 is your Operator it's ok. You are asking for the Operator, maybe to ask her/him to dial a phone number to which you do not have acess and transfer it to you.
Return to “GENERAL”
