Q-sig ans Samsung os500
seriosha
Post by seriosha »
Does anybody know it is going to work together?
Oxe r 7.0
If your Samsung PBX supports QSIG with correct parameters there should be no problem.
Tests of integration may have to be done on your side and Samsung one.
seriosha
it's work only with Isdn..
Post by seriosha »
I can't call from OXE to Samsung.
Whem ext on Samsung side sending busy signal.
T3 show me that digits going to Samsung.
I see that one channel is busy
here is my settings
Q931
1 entity number
Trunk Group:88
B channel choice=yes
cos 19 (in the manual written that is should be 1919 - what is that)
Shelf/Board/PRA2/Digital Access set
Network mode=yes
CRC4=yes
when I dial 88(trunk group) 002 (node Samsung) 202 (ext)
Samsung is refusing the call
by the way I can't set synchronization on the board! Oxe says that NO synchronization in MG. The PRA board installed on 3(coupler) 6 slot
Does anybody knows what is happening?
Well if you see that with t3 you send digits to Samsung and that with trkstat -r [trk_grp_number] that your channel is being taken the problem may be on Samsung side.
What does that PBX says on his traces? Does it receive Alcatel number dialed? If not check your NPD or Routing number for the Samsung on Alcatel side.
Wo, no synchro? On the MG? Is your MG configured? Are you certified? Is anybody helping you there? Any knowdledge on OXE? Or just first time trying to? I'll recommend to get help on site. Integration of PBXs needs good knowdledge on what all combination of parameters can do.
seriosha
Oh
Post by seriosha »
I was visiting a basic course for 5 days but now I see it's was so basic...
I configured 2 PPA board on first coupler and everything goes good except Q-sig.
Actually I don't' cirtificate right from Alcаtel :oops:
I know that it seems as dump question but I've no choice..
Please help
lol don't worry i'm not certificated on oxe neither :p i'm more a call center/applications guy, but my daily work makes me manage it and learned a lot "destroying" it :D And now i'm able to install my OXE's and work fine.
And there is no dumb question, we all have been where you are right now. That is why we are here, to help.
Can you please post all your trunk group config? All screens.
Also how are you routing to Samsung, NPD? Routing?
seriosha
Okey
Post by seriosha »
I'm going to do that very SOON!
Show t3 trace. About syncro - you cannot use priority from 0 till 199. Use 200 (synchronization by domen). Priority from 0 you can use in ACT (4400 hardware) with CPU5,6,7 and INTOF board. After IP (MG with CS or AS) or RT2 used priority from 200.
spring
Post by spring »
If it is a All-in-One (3 MR3 link together via MEX and HSL) configuration, the sync. can only be assigned on the first ACT such as ACT1. ACT 2 and 3 cannot be changed.
Return to “GENERAL”
