Linux tricks
kondalisa
Linux tricks
Post by kondalisa »
Could somebody post Linux Tips and tricks related to OXE Hard disk Crash recovery or Software maintenance of OXE using lynix tips or tricks.
OXE uses Self-Monitoring, Analysis, and Reporting Technology, or S.M.A.R.T. (sometimes written as SMART), is a monitoring system for computer hard disks to detect and report on various indicators of reliability, in the hope of anticipating failures.
This tool comes with Linux.
You can find more information on the WikiPedia
jasic
Post by jasic »
For OXE maintanace commads typ help at the console.
kondalisa
Post by kondalisa »
Is there any document available pointing procedure of recovering OXO and OXE after being HDD crash..does somebidy have thier own made document??
Best way to recover is have a backup...
tgn
Post by tgn »
yes, indeed best you've a backup.
if not...
in case of oxe
take the hardisk to a normal pc and connect it to the ide-bus (or better ide to usb connector).
i prefer linux on this pc. but you can also use a windows with "linuxreader".
in case of an oxo... because of the encryption of the filesystem, i'm thinking there's no way to recover something.
murraya
Post by murraya »
Hi, I've found on an OXO as the database is moved to the NAND flash you just need to put the new drive on the CPU and it will configure the data back to the new drive. Some things like greetings will be missing but if a backup is onhand then no issue
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
trjm
Post by trjm »
There is a technical communication from Alcatel about this, TC0536 called "RECOVERY OF CLIENT DATA ON DEFECTIVE OR INVALIDATED HARD DISK".
I haven't had the need to try this myself, but maybe it can help you?
Feel free to attach it ! :)
murraya
Post by murraya »
Here it is....
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Return to “Linux tricks”
