Hi all
Some One Tell me how I can make Substitution feature on OXO system
So i can take my Extention number through any set pone
thank & Best Regard
Substitution
Chamizo
Hello:
For subtitution on OXO you should use the account code prefix and in the account code table you need an entry with the parameters on YES, YES , GUEST, DEFAULT. To use this feature you dial de account code prefix, the account code you create (any length) , your extension number and your personal code. This only works for making external calls with your barring category on another phone.
There is not need to dial the Account Code created. In the Dial Plan, at the base of the Account Code prefix, you can configure directly the account code created, so This preffix always will mach directly to the Account Code and only will ask the user number and the password.
Of course, doing that, the prefix can only be used for susbtitution. By default, the account code use for substitution is the 1000 (if you did not erased it).
What I mean is, for example:
Feature: Account Code NEw
Star: #87
End: #87
Base 1000 (This is the Account code created by default to substitution)
If you erase the 1000 account code you can creatinn as Chamizo says.
Star: #87
End: #87
ileana
etc
