OXE 9.1 /usr2 100% full
Locked
nowi
Post by nowi »
I just did an OXE 9.1 installation on VMWARE. After Linux and Callhandling /usr2 is already full!
/dev/hda9 388M 388M 0M 100% /usr2
Therefore I cannot install the current static patch.
Anyone the same problem? I already did a look at the installation files. I'm looking for the place where the partitions are created. No luck so far.
Nowi
freedom
Post by freedom »
No problem over here.
i did a clean install on a vmware with a 20GB harddisk declared in the virtual machine.
After installing both R9.1 package and patch (12), the usr2 is only 40% full:
/dev/hda9 1011928 378172 582353 40% /usr2
But it seems that your partition is much smaller then mine.
What is the harddisk size you set in the VMware machine?
nowi
Post by nowi »
I was trying to upgrade from 8.1 to 9 and I have used a 8G virtual disk, changed it to 12G and everything was fine with a clean install....BTW, I found the config files for the partitions:
dhs3mgr/i1605/pcmao/boot_res/linux/67.0/install/config
Depending on the HDD size the layout is different for 2;6;10;19;26;40 and 80G drives
Ciao,
Nowi
Locked
Return to “Other”
