Account code???
marlon74ph
Account code???
Post by marlon74ph »
Our client want mobile and international call to be barred.
When they want to dial international or mobile they want a password or code to access the trunk lines.
system: OXO R4.1
Can somebody help me how to figure out the configuration and how to use to our digital sets (4039, 4019 and 4029)
regards,
marlon74ph
Martijn
Post by Martijn »
You can try to program it in the collective speed dialing, simpel program an area code.
Example speeddial 7000 (0031)
You press 7000 on an barred set. The set whill dial this number, only thing you have to do is to press the digits of the city and the phone number you want to call.
This is the only way, i had no time to test in de Omc rel5.10 but in rel 4 this works.
Grz Martijn
marlon74ph
Thanks,
Any other solution?
regards,
marlon74ph
henk1964
Post by henk1964 »
Using account codes.
In traffic sharing and baring create account codes.
Change the default password for an extension that you use.
Dial the account code prefix,
dial the account code you created in the sharing and baring.
dial extension number you normaly use
dial the pincode used in this extension
dial the phonenumber
This works ;-))
marlon74ph
thanks a lot..
marlon74ph
Return to “GENERAL”
