Blind Transfer
mabrgron
Blind Transfer
Post by mabrgron »
I was aked from one of my sites if they can do blind transfer
Call comes in and answered
they press the Transfer key
dial the DN
press transfer key again
you hear ringing up to 5 times but the set never rings
yet a supervised transfer works fine..
thanks in advance
Mark
aflores
Post by aflores »
Look at the System Miscelaneous / Fuature Desing Tranfer by On hook.
By the way, You mean AA transfer or Operator Transfer?
jan
Post by jan »
Put caller on hold dial destination and then hit transfer.
aalmanzar
Post by aalmanzar »
what do you mean: Look at the System Miscelaneous where can I find this????
Return to “Configuration”
