Unable to Supervise a Ghost Z on a 4020
tjm0852
Post by tjm0852 »
I can also not modify or reprogram the keys that supervise the ghost z. If I delete the ghost z I get a MCDU error. If I try to reassign a button that supervises that ghost z, it says command succeeded, but the programming has not changed :x I can not program the key as Not Assigned, nor can I change the extension it supervises. It reacts like the chages have taken, but when you check them again there has been no change. All programming done through mgr. Only thing is first ghost z created since upgrade to 6.1 software. Ghost z created as false then modified to True.
Any suggestions? I am stumped
tjm0852
Post by tjm0852 »
A double BASCUL fixed the problem :!:
I just saw this post.. Are you sure you were not making changes in the standby CPU ? Just asking.. :-D
When you have problem with supervision try repaire situation with "multitool REPAIR" command.
tjm0852
Post by tjm0852 »
frank wrote:I just saw this post.. Are you sure you were not making changes in the standby CPU ? Just asking.. :-D
Changes were definitely made in the main CPU. I never use the Standby CPU address. :lol:
vad wrote:When you have problem with supervision try repaire situation with "multitool REPAIR" command.
I will have to try that command, thanks.
Return to “Users”
