Dear all,
My system time is correct when checked in Swinst for both CPUs. Display on the digital sets show hours ahead or behind. NTP is not started. I don't use time update in PRI.
Anyone with and idea?
Good day
OXE system time
mick405
I've seen this issue before too. And in all our cases running a double-bascul was the solution. Especially if you have changed the time zone in swinst.
We have found that when sites were installed they are left with a French DB which obviously has it's timezone set to change during the year with DST. If you're in a country in a different timezone to France/Paris then you're going to run into problems.
As suggested by aponterules check the time in mgr/system as well. I'm almost 100% sure (from memory) that this parameter is the one which affects the time displayed on your phone sets.
Get the CS's double-basculed.
