Unable to install Chorus to my VMware
afeef
Post by afeef »
Hi Alcatel Engineers
I am unable to install chorus R6.0.1 to VMware, i have try a lod but bad luck, getting error (cannot open TFTP connection)
Appreciate if someone could explain me the problem.
Afeef
sera544
Post by sera544 »
Hi afeef,
U have to select company network not a direct cable from pc installer go thro below link it can help u out...Appliance server is not working try with Blade server am sure it will work,
After u select the company network, u have to put the Vmware Mac address in the Ethernet address field..
http://slimphony.blogspot.com/2006/10/o ... setup.html
cheers
afeef
Post by afeef »
Hi Sera
Thank you for your comment
I have setup all as your suggestion, i have select Bland Sever, and company Network and VMware Mac in the Ethernet address. but bad luck getting same error. i cannot attached the scrren shot in this Thread but i will sand you the screen shot.
Afeef
afeef
Post by afeef »
Hi Engineers,
I have try to install chorus R6.0.1 in my vmware. I have followed "Http:\\Slimphony site recommendation step by step in that website.
But when I press apply on PC-installer getting following error.
PXE-E11 ARP timeout.
PXE-38 TFTP connection not started.
PXE-E53 no boot filename received.
Appreciate if someone could help me to solve this problem
Afeef
sera544
Post by sera544 »
HI afeef,
it should be a simple process, u knew that u have to select Blade or appliance server and company network then put ethernet mac adress on the pc installer
then make sure u have selceted the c:/ from pc installer and under c:/ check dhs3mgr folder u have created.then copy the versions under dhs3mgr, there should not be anyother folder like example
c:/dhs3mgr/h1301/h1301 it should be c:/dhs3mgr/h1301
if above options are fine with u after u click apply on the pc installer check from task manager go to process tftp and dhcp process are running or not
make sure only one network adapter is working, if u have wireless switch off & network adapter just configure the ip address and subnet no need to configure the gateway or dns if u have it remove and check it out...
Hope this will help u...i am running Vm ware 6.5.1 with out any issues,
cheers,
Pandian
afeef
Post by afeef »
Pandian, Thank you very much.
I will try and let you know.
Afeef
afeef
Post by afeef »
Pandian
I have flowed by procedure as your advice but i cant load chorus in my VMware. when i press Apply on PC installer getting error (DHCPD file_receive failure from eth0)
Afeef
afeef
Unable to install chorus on VMware
Post by afeef »
Hi Alcatel Engineers.
Can someone please help me to solve flowing problem?
I am trying more then 3 weeks to install chorus R6.1.1 on VMware 7.x.x. but still unable to solve the problem.
when i install VMware in my PC it's automatically install 2 network adapter like vmnet-1 and vmnet-2
im my pc have 1 in-build lan connection and other 2 lan card 1 is ADSL other card i am using for programming OXO and OXE pabx.
In-build lan card address is, 192.168.4.12
and ADSL lan address is, 192.168.1.3
Pabx programming lan card address is 192.168.53.100
VMnet-1 address is 192.168.153.1
VMnet-2 address is 192.168.247.1
PC Installer setup is
Call Server type: Blade Sever.
Call handling version: F1603.
Country mv
Installation type Standard.
Network type: Company network.
Network interface: 192.168.153.1
IP address: 192.168.153.2
Ethernet address: 00:0c:29:ae:de:f8
when i press Apply from PC-installer getting error like.
(DHCPD produced following error message: receive packet failed on eth1 connection reset by peer)
i have attached the screen shot.
Afeef
afeef
Post by afeef »
Problem solved install PCinstaller R2.17 everything working ok now. thank you all
prasad0777
Post by prasad0777 »
do you have any idea why VMware has two virtual adapters when we installed and which one is usable ?
Return to “Other”
