I just arrived is this center and they way they are resetting voice mail passwords is by hyperterminal and connecting to the PCX by modem and changing password from the hyperterminal interface.
I was wondering if there was another way around this or if this is the only way?
Another way would be to set the voice mail box temporarily accessible without password, then we could change the password from the voicemail but I don't nkow if it's possible with this system.
The mailbox type is 4635
Thanks!
Resetting voice mail password 4635
4635 via mgr
Follow the documentation and if having issues contact your AL business partner.
Good luck!
Good luck!
KIKA
Re: RE: 4635 via mgr
Hi!swinstu wrote:Hi,
Good luck!
Do you still have this document?
Enviado desde mi Nexus 5 mediante Tapatalk
- Krusty65
Re: Resetting voice mail password 4635
