Need help
Everything about the PWT, IBS, RBS, DECT..
garth
Need help
Post by garth »
I need help de-registering a DECT Handset. A user has accessed our omnivista software and just removed one of the GAP numbers and now I am not sure how to de-register the DECT Station with a new number as it just says "unknown handset" on the screen now.
Can anyone help?
wizzy
Post by wizzy »
if I understood correctly....
Execute the command dectsets to see if it is registered. If yes then use dectrm to deregister
As far as I can remember, in this case I created again in omnivista the user and then executed through terminal the command dectinston.
spinman
Post by spinman »
If u dont know the number of a Mobile x00 u can do a "eeprom reset"
Hold the red and green buttons down at the same time u switch on the handset, in the menu choose 4. Eeprom reset. this will reset the handset.
wizzy
Post by wizzy »
spinman wrote:If u dont know the number of a Mobile x00 u can do a "eeprom reset"
I didn't know that. That's great and useful :D
garth
Post by garth »
woohoo! wizzy your an absolute lifesaver.
Thanks heaps
Garth
Eliott_DUP
Post by Eliott_DUP »
You can also de-register the handset in the service menu.
Press OK
Go to the icon with the wired and wireless set
Press OK
Enter the password 314987
Press OK
Choose the System
Press OK
Choose Uninstall
Press OK
:wink:
Return to “Wireless configuration and sets”
