My TeamWork in a Virtual Host
tincho.rn
Hi. Does somebody test My Teamwork in a virtual host? Regards.
RobertBreu
i have tested it with Microsoft Hyper-V but it doesn't worked (It hung up at the installation-process). The Host was a HP ProLiant DL380 G6. In the Teamwork-Documentation it says you have to contact technical support if you want to install it on this machine. I had no time to do this...So i don't know if it fails because of Hyper-V or because of the host-machine.
Greets
Greets
banfield
sedel_m
Re: My TeamWork in a Virtual Host
Hi guys,
We are planning a deployment o a customer where vmware is a must. So was wondering if there any production successful experience? We are talking about 200 users initially so it is going to be hard...apps that are not supported on a vmware platform are being left apart...so if tw doesn't do it will be discarded almost inmediatly
Thanks!
Thanks!
banfield
Microsoft Lync with ICS 6.5 that is coming soon
Lync has no problem with virtuell environment; only thing needed to take care is that it needs its own Nic. When it comes to Teamwork i don´t know if they have fixed the virtuell issue now when new version coming and BiCS
Yes I do know Lync will kick our asses if we don't put up to date.
Can't find nothing on BPWS about virtualization on TW...
OSkey
Did anyone get it working on a VM? If so did all the modules/add ins work successfully?
