Sagem ATA FOIP SIP
Sam Kent
Sagem ATA FOIP SIP
Post by Sam Kent »
Hi guys,
Got an issue where i have Sagem ATA 101S FoIP connectors but they dont seem to FAX!
They are set up as SIP Devices as per the inter-working report and i can ring to it and from it but when i send/recieve a fax (internally or externally) the fax will ring but the will not handshake. Just keeps ringing and ringing?
First of all i thought it was to do with Compression in the IP domain but have turned that off etc....
Any ideas or if any1 has used them before?
tincho.rn
Post by tincho.rn »
Hi. Take into account that OXE only use T38 for FAX. So, if thoose ATA don't support T38 it wont work. However, make some traces. Regards.
Return to “SIP Extension”
