SIP device external outgoing calls
ybelal
Post by ybelal »
Is there any limitation from alcatel to make outgoing external calls from SIP device? I have OXE Rel9.1, When i create number with SIP extension then external incoming and outgoing (DID/DOD) Both working fine from that extension but when i create a SIP Device with same extension number, the only external incoming calls to that number work but i can't make external outgoing calls from that extension(local call working)!!
Any advise please.
Thank you.
enio.eltz
Post by enio.eltz »
Hi ybelal
It has. up to R8, oxe only had SIP device. From R9, oxe has SIP device and SIP extensions with a lot of possibilities for using oxe features. Oxe databook has a piece that has SIP END OF POINT LEVEL OF SERVICE. It explains so well this difference.
Maybe experts from this forum have a better explanation about this case.
Regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ybelal
Post by ybelal »
Thank you. . Actually when i try from sip extension then i can take outgoing trunk by dialing the prefix ( which is *9 for me) and can make out going calls but when i create same extension with sip device and try to take outgoing trunk by dialing *9 then it refuse. so, Still waiting for experts opinion in this forum on this issue
trjm
Post by trjm »
If I recall correctly one is supposed to use SIP Device if a analog adapter with a fax connected. Faxes usually can call outside, so it is strange. Is there anything in the SIP trace?
ybelal
Post by ybelal »
I am using x-lite sip client (x-lite, 3cx...)from a pc which is connected to oxe network. Local calls working fine, only problem with external outgoing as sip device.
trace attached.
ameno_12"
Post by ameno_12" »
I have the same problem with the external call, possible firewall problem ( port udp or tcp rtp....)
minhchaugiap
Post by minhchaugiap »
please help me?
I also encounter this problem, when i Call this X-lite to Extension no problem, but i called from the extension to x-lite then pick up the phone " x-lite " when it has always failed.
ybelal
Post by ybelal »
My actual problem is making outgoing external calls from sip device.I have attached the traced also. with my previous mesg here (msg #5)...need help,please.
ccube
Post by ccube »
Dear ybelal,
Could you please attach traces for working and non-working External Calls? And also, please use motortrace 3 on the OXE so that we could see all the traces.
murraya
Post by murraya »
if using sip device (not extn) check toll level on the trunk gp (PNC).
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Return to “SIP”
