USB - PCMCIA Acan recordDAPTOR
aflores
Post by aflores »
Hello Friends.
I'm looking for an USB-PCMCIA adaptor compatible with the Audio Station so I can record the flashcards for the 4400/OXE Voice Guides.
If anybody of you has this information I will appreciated tell me the brand and the model.
Thanks in advanced.
AFlores
Konstantinos.E
Post by Konstantinos.E »
hi!
i think there is not such a thing.....if you r lucky you can find a drive just for tower pc.....or just find an old laptop...
OXE_4400
Post by OXE_4400 »
I have used some old laptop with Windows 95 and installed AAS software. I tried to find some drivers for more new PC but ...
Windows XP doesn't work with Flash cards without specific drivers.
Return to “Voice Guides”
