Reset OmniVista Password
luis.molinas
I need to reset the password of the OmnivVsta (oxe) because the pass has expired and lost.
Can you help me witht this problem.
luis.molinas
MR_PT1
Go to C:\4760\bin, find the DirManag.exe application.
Login: cn=directory manager
Password: "The directory manager password used during Omnivista installation"
0=directoryRoot --> administration -->administrator -->AdminNmc --> change the field "user password" --> Ctrl + S
Try to connect with the AdminNmc login and the password.
Good luck!
Good luck!
luis.molinas
luis.molinas
MR_PT1
luis.molinas
The situation is as follows:
When I enter the user "cn = directory manager" and password (empty) pretends that connects but does not let you modify anything.
I think the first thing you need is to recover the password of "cn = directory manager".
You know how it could reset the password of the user "cn = directory manager"?
rpdeguzmanjr
Re: Reset OmniVista Password
Hi MR_PT1,
Is there any chance to access the Omnivista8770 if also the installation password was for cn=directory manager also forgotten?
best regards,
best regards,
