Flash corrupt
ar4uall
Flash corrupt
Post by ar4uall »
Flash on OS6850-8M is corrupt.
Switch is booting to miniboot.
Here's a log:
[Miniboot]->reboot
mgi0 Interface Down
mgi0 Interface Stopped
WARNING: "sysResetHardwareFlag" flag is SET, forcing CMM board reset.
AOS BootSelector Version: 6.6.1.636.R01
Creation Date: Oct 10 2009 11:49:10.
Press x to choose XMODEM...
Press s to STOP AT MINIBOOT...
Reading kfminiboot.bs from /boot ...done:
Uncompressed kfminiboot.bs @ 0xA10000...
Running Miniboot...
Detected board DB-98DX4122-48G
Ctrl env init... Done.
CPU if init..... Done.
Done. Actual freq = 96153Hz
Memory on board initialized .
Init Phy port 0 .. Done
Init Phy port 1 .. Done
Power up GMII port0 .. Done.
Power up GMII port1 .. Done.
Detected DRAM size 256MB
Detect SysClk 320MHz
Detect Tclk 200MHz
Marvell Controller initialization Done.
Eth int Ctrl.... Done
GPIO int Ctrl... Done
PEX int Ctrl.... Done
PEX0 init....... Done. DEVICE type selected
XOR int Ctrl.... Done
XOR init........ Done
mvCtrlInit2..... done
PCI auto config. done
sysHwInit2...... Done
CS EEPROM Module ID: 42012291 , System type: metro 8 copper ports with stacking or uplink port - Kin
gfisher
System Configuration
BSP Ver: 1.2/1.1.01 Creation date: Oct 10 2009, 11:57:45
CHIP : MV88F6281 Rev 2
CPU : ARM926 (Rev 1)
BOARD : DB-98DX4122-48G (0x7)
CLOCKs : tClk = 200 MHz, sysClk = 320 MHz
pClk = 800 MHz
NAT_SUPPORT = Disabled
VFP_SUPPORT = Disabled
FlashFX initialization required 766ms
Reliance File System Driver
File System initialization required 0ms
FlashFX initialization required 83ms
Target Name: vxTarget
Ethernet port #0 initialized
mgi0 Interface Loaded
mgi0 Interface Started
mgi0 Interface - Link Up, 1000 Full
Attaching network interface lo0... done.
Adding 7221 symbols for standalone.
Can't open file (/flash/boot.params)
'/flash/boot.params' does not exist. Creating it with defaults.
asciiBootParamsCommit() failed.
Not able to create boot parameter file.
Boot parameters are:
'flash(0,0)cmm:default u=admin pw=switch cb=9600 cp=none cs=1 cw=8 cm=modemControlOff'
AOS miniboot version: 6.6.1.636.R01
VxWorks (for DB-98DX4122-48G BE MMU ARCH 5) version VxWorks5.5.1
KERNEL: WIND version 2.6
Made on Oct 10 2009, 11:57:45.
Copyright Wind River Systems, Inc., 1984-2006
CPU: DB-98DX4122-48G BE MMU ARCH 5. Processor #0.
Memory Size: 256 MBytes. BSP version 1.2/1.1.01.
Portions of code copyrighted by Alcatel Internetworking, Inc. 1994-2009. All Rights reserved
Portions of code copyrighted by Apptitude, Inc. 1997-1999. All Rights reserved
Portions of code copyrighted by Free Software Foundation, Inc. 1989,1991. All rights reserved
Portions of code copyrighted by The OpenLDAP Foundation 1999-2000. All rights reserved
Portions of code copyrighted by Theodore T'so 1994,1995,1996,1997,1998,1999. All Rights reserved
Portions of code copyrighted by RSA Security, Inc. All Rights reserved
Portions of code developed by the Carnegie-Mellon University.
'/flash/certified/' does not exist, creating...
'/flash/working/' does not exist, creating...
Attempting to load from the CERTIFIED directory...
Loading kernel from '/flash/certified/KFos.img'...
Cannot find component(alcatelNetworking_kernel.lnk) in package(/flash/certified/KFos.img)!
Cannot find component(kernel.lnk) in package(/flash/certified/KFos.img)!
Unable to load kernel image from file '/flash/certified/KFos.img'.
Unable to boot from the CERTIFIED software release.
[Miniboot]->
Here's what happens when i try a diskInit:
[Miniboot]->diskInit "/flash"
Couldn't open file system on "/flash".
Perhaps a dosFsVolFormat on the file system is needed.
value = -1 = 0xffffffff
Here's the what happens when doing a diskFormat:
[Miniboot]->diskFormat "/flash"
Couldn't open "/flash".
Is there anything i can do?
Tried to zmodem some files... but transfer stops in 1 second.
Can anyone help... is there a CF card inside the unit?
Can i replace it or format it somewhere else?
Thanks.
Re: Flash corrupt
Have you tried the attached Techtip (new fs)? If this isn't helpfull you have to do a replacement of the switch.
cuong955
Re: Flash corrupt
Post by cuong955 »
silvio wrote:Have you tried the attached Techtip (new fs)? If this isn't helpfull you have to do a replacement of the switch.
Thanks so much
Ruheal Maqsood
Re: Flash corrupt
Post by Ruheal Maqsood »
Dear Silvio.......
You are a CHAMPION MAN........ THUMBS UP !!!!! :)
Daniil
Re: Flash corrupt
Post by Daniil »
Attached manual does not help if we have the situation
can anybody help what to do?
mos
Re: Flash corrupt
Post by mos »
how did you solved the issue
Return to “OmniSwitch 6250”
