gd config
jyotimajumder
gd config
Post by jyotimajumder »
how to configure GD card in common hardware?
mothinx
Re: gd config
Post by mothinx »
Connect a COM/RJ45 cable on Consol.
Login as admin.
Validate superuser login by enter #su
and you can use mgconfig to configure your GD.
Re: gd config
mothinx wrote:Connect a COM/RJ45 cable on Consol.
Login as admin.
On GD3 login directly as root.
